Home > Maintenance & Mods (L322) > Preventative maintenance for turbos
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Good quality fully synthetic oil and filter change every 6 months regardless of mileage, circa £70 a time if you diy,
against £2-3000 to replace turbos and periodic egr additives seems a no brainier!
Can’t fathom why anyone would leave oil changes to yearly or longer with equally high mileage’s....Russian roulette! Shocked 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #484454 27th Jul 2018 1:42pm
Klunk
What is the best oil ?
Not meaning to start an oil war ( i come from E39 M5 forums and Oil is one hell of a contentious issue)
Post #601235 20th Jul 2021 10:47am
dingg1
Anything that meets the required specification.
War over Cool
Post #601238 20th Jul 2021 11:11am
ur20v
A Trap
Deleted
Post #601242 20th Jul 2021 11:20am
Klunk
War over Cool
Yep agreed and quality oil looks like 55 quid for a change - so that’s a bargain !
Post #601255 20th Jul 2021 1:05pm
Klunk
ur20v wrote:
Provarmint wrote:
Has anyone used Forte turbo cleaner?
Personally I think all these intake/egr/valve/combustion cleaners are snake oil. Anyone that has taken a diesel apart and cleaned it will know how stubborn the carbon/soot deposits are, it can literally take a blow torch and wire brushes to remove.
My advice is to blank/disable the EGRs to stop this soot from getting in there in the first place. What is there already will remain until you strip the engine and mechanically clean.
As for the turbos maintenance:
Clean fresh and suitable grade, spec synthetic oil changed very regularly (max 6k miles)
Intercooler/intake hoses and manifolds need to be leak free, any boost leaks will over speed your turbos.
Gental driving until the oil is warm and a period of slow/steady driving and idling before switching off to remove the built up heat in the turbos that bakes the oil and blocks the oil ways and bearings.
Don’t drop dirt, rocks or bolts and screws, plastic etc in the intake system.
Don’t chip/tune your diesel, it will over speed your turbos,
Other than that they are maintenance free.
EGR blanking and mapping anyone know anywhere in north wales for this ?
Any downsides?
Post #601256 20th Jul 2021 1:06pm
ur20v
A Trap
Deleted
Post #601268 20th Jul 2021 3:38pm
ur20v
A Trap
Deleted
Post #601269 20th Jul 2021 3:39pm
Klunk
Yes i have a 2009 3.6 - have looked and can’t see a DPF…
I have read in a few places that the EGRs need coding out after blanking off.
Saw some poor guy who’s turbos imploded after he blanked his off without a remap
Confused…
Post #601335 20th Jul 2021 11:38pm
ur20v
A Trap
Deleted
Post #601407 21st Jul 2021 5:01pm
Klunk
Thanks, i took the car to a specialist today who echoed a lot of what has been said on here, i.e. it’s usually actuators, he said he hasn’t seen much trouble with EGRs .
He was more concerned about the gearbox being serviced.
Post #601425 21st Jul 2021 7:05pm
ur20v
A Trap
Deleted
Post #601480 22nd Jul 2021 2:32pm
