![]() | Home > Maintenance & Mods (L322) > Battery chargers / conditioners |
DaleL322 Member Since: 04 Mar 2021 Location: Stamford Posts: 176 ![]() ![]() ![]() |
Not exactly what you asked, but I use a CTEK MXS 5.0 on my AGM and it works perfectly... just incase you wanted some feedback on the CTEK
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
I got the CTEK MXS 5 and it wasn't powerful enough for my battery so upgraded to an MXS 10 . Fantastic bit of kit and worth every penny |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
I keep my 2011 TDV8 on trickle charge using the CTEK MXS 5.0 and haven't had any battery issues, charges fine and keeps it topped up perfectly 2011 TDV8 Vogue SE |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Ctek Mxs 10 here via a towing socket adaptor into 13 pin electrics Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
Ctek 7 here... connected through towing electrics. Used it for years and good on AGM.
![]() Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
Thanks for all the reply’s guys, I’m assuming no one has used the numax I just wanted to make sure If it was safe to use or if I needed to change to a ctek 2012 Range Rover Westminster 4.4 TDV8
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 606 ![]() ![]() ![]() |
Hi Furnitureman,
