![]() | Home > Maintenance & Mods (L322) > bottom tail gate carbon fiber |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1300 ![]() ![]() ![]() |
You carry on posting mate. I like reading how others are personalising their cars. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1234 ![]() ![]() ![]() |
Same as above post, keep posting, everyone has different ideas. nice job. |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
i no merchy never again takes me 3 days now to get back to normal drink plenty of water befor you go to bed saves the big head banging . mine was the same peeling of so i had some panel wipe sprayed it and used a scraper and got of all the cream coating light wire brush wear the grain is and clean with solvent remover and it came up like this then went over with the carbon i for got to take a picture of it will tomorrow . use heat gun on the bende bits i got 50 mm wide tape thank for your comments oggy forgot when you do the handle over cut it by 5mm and you can fold it under the edge push it in with a plastic tool it will not peel from the edges wifes shouting bath is ready new vehicle purchase
Looks real good. |
Cheers for the pics, excellent job |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Nice job and a good idea, much neater... just a tip, when I did the interior plastic trim on fatty offroader I used Vinyl wrap adhesive promoter, for tight curves and edges it's excellent....
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 453 ![]() ![]() |
That looks so professional! I’d be tempted to do the rear plastics above the vents in the 2nd row on the early ones as they always seem to flake off |
Here you go, give you an idea what it looks like....
That completely transforms the feel and look of these older range rovers! Brilliant I’d been looking at them and guessing it would have to be repainted but that is excellent |
Here's a few more then
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
that's a £2k option on a Porsche!
hi haylands i just re read this post and mist your edit just like to say what a nice job you done with the carbon fiber that would of been time consuming nice one new vehicle purchase
