![]() | Home > Technical (L322) > Best Head Gasket Sealing Formula? |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
None of the aforementioned. None of them work. The combustion pressures are way too high for anything like that to have a hope of working. |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
check out this post
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Might as well just pour a bag of sugar into the cooling system with that mate instead of k seal etc |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
So how do I get rid of the car then?
Depends on who you plan on selling it too. If you go down the wbac route then you'll prob be OK but other dealers may be able too chase you for a faulty sales of goods route |
Ok, I won't bother with any liquids - I'll try selling privately with a head gasket problem and if not, I'll be sending it to auction and cutting my losses. 2015 Range Rover Autobiography 4.4 SDV8 |
Probably the best option. However, before you do, has it been confirmed as a head gasket? Might be worth shelling out £100 or so for a decent garage to perform a cylinder leakage test just to be sure. Please note there is a big difference between a compression test and a leakage test. A compression test is fine for a burnt valve or suchlike, but a leakage test is far better at detecting a head gasket leak, especially if it is only minor.
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 ![]() ![]() |
That seems sensible Sam, otherwise Gary you could be throwing away a lot of money.
The quote was £5k for a head gasket repair.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
Whack 2 bottles of steel seal in it, see if it improves, trade it in... |
