Home > Technical (L322) > RR not starting, Canbus fault
kenheaton
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
Hi
I was out in my l322 on Friday, stopped at the shops, car wouldnt start again, just spinning over/
Called AA they tried easy stsrt , it ran for a short period whilst being sprayed then stopped. Patrol plugged his dignostic in and it wouldnt communicate with the car. Big yellow taxi home for the first time in 18 months of ownership so not too bad.
Charged battery still just spins, tried hard reset disconnecting and joining pos and neg battery
plugged breakout box in got power but flashing can high and can low. Checked resistance between these 2 believe it should be 60 ohm got 8 mOhms
Fuses all ok
Was going to try disconnecting Headlamp ecu which I believe is behind kick panel
Any ideas guys please
Post #601120 19th Jul 2021 2:18pm
Fuel pump behind the passenger side cill would be a good place to start, assuming of course there is fuel in the tank. Very Happy
Post #601148 19th Jul 2021 4:19pm
