![]() | Home > General > Picking up a 2009 TDV8 3.6 what should i look for |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4320 ![]() ![]() ![]() |
Blank the EGRs with an ebay kit on Day 1.
Klunk Member Since: 12 Jul 2021 Location: North wales Posts: 72 ![]() |
Thanks,
In terms of turbo replacement, if it goes south, how much are they to replace?
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 ![]() ![]() |
I’m in the same boat as you, from what I’ve read turbo replacement is between £2.5-£3.5k on the FFRR and you’ll get a mix of people quoting for doing in situ and bigger strip down.
Sandman77 Member Since: 26 May 2021 Location: Glasgow Posts: 33 ![]() ![]() |
When viewing, open the rear left cuddy box in the boot area and make sure it is bone dry. Water leaking into this area can cause damage to a lot of electronics which are expensive to repair/replace.
3.6 can be blanked. 4.4 much more difficult and not a DIY job.
Check all the rear wheel arches for rot
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I think the facelifted 2010 MY 3.6 had a DPF as standard.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 ![]() ![]() ![]() |
Re DPF, mine is a 2010MY first registered in September 2009 and doesn’t have a DPF.
You forgot;
Haha thanks all - really helpful and also funny replies |
Sean Member Since: 11 Mar 2013 Location: Up north Posts: 46 ![]() ![]() ![]() |
Just enjoy the car it is really special |
That’s what i am hoping
