![]() | Home > General > RR L322 3.6 TDV8 - Buying Advice and Retro Fit Tow Bar |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Witter bars are good, so are Brink. I had a witter on SWMBOs Skoda, was very robust and easy to take on and off. There is nothing that can't be fixed with a hammer😜😜
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 453 ![]() ![]() |
Is it just the EGR failure that causes the turbo to pop on the TDV8 and td6? |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
L322 is notably heavier and that extra fat gives more planted feel when towing bigger stuff. |
longd Member Since: 24 Oct 2020 Location: West Midlands Posts: 95 ![]() ![]() ![]() |
Rather than start up a new thread …
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 899 ![]() ![]() ![]() |
I am in the same boat, and am also not sure if all the wiring and ECU are always installed in or cars by default or we need to retrofit |
From what I have gathered , through very limited knowledge, apparently it’s a case of fitting tow bar and wiring it to the existing loom, then programming through id tool ? This is all from a conversation with a Volkswagen mechanic … so I wouldn’t take it as gospel ?! Hopefully get some confirmation from someone who has already done it ! |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1454 ![]() ![]() |
If you get a proper electric kit with the towbar, then it'll be a loom and ecu box with the proper cable connectors to plug into existing loom stuff in the side rear sections of the boot are. The L322 will be wired for the towing loom to be added to it. On my first L322, I bought a genuine loom ( was same price as towbar suppliers ). On my Freelander 2, second L322 and Evoque I bought the loom kits as offered from the towbar suppliers, and they all worked just fine.
the rear bumper needs removing to fit a towbar
