![]() | Home > Maintenance & Mods (L322) > Trailer connected |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1205 ![]() ![]() ![]() |
Hi, Furnitureman if you can do that it will be a lot of help to people on here? I will then write to Pat at Gap with your solution? |
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 ![]() ![]() ![]() |
My rear parking sensors don't beep when I have the van on the back.
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
Same here mate 2012 Range Rover Westminster 4.4 TDV8
Hi, Found the section in the CCF as OP, I have got a new IID tool updated today and found the extra file section so will check it out tomorrow when I pick up the van? |
MisterT Member Since: 08 Mar 2019 Location: Lincolnshire Posts: 29 ![]() ![]() ![]() |
My 2011 AB has a factory tow hitch, the parking sensors and rear fog lights deactivate when the 13 pin socket is connected. |
So it would appear that as Gap is in Canada they cannot check a 13 pin or 7 pin electrics? All he has been able to refer me to grant me a full CCF file to make it work? which I have done and going to check out tomorrow when I connect to the caravan.
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 250 ![]() ![]() |
My sensors turn off when trailer connected.
Nearlee |
Well, guys |
Good stuff tinman |
Glad I could help out mate, sorry I didn’t get round to checking how I did it, a trip crabbing to Conway took me out for the day, but glad you sorted it 2012 Range Rover Westminster 4.4 TDV8 2006 Discovery 3 HSE 260k miles and still going strong with a new owner |
