Home > Maintenance & Mods (L322) > Trailer connected
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Trailer connected
Hi Guys
How many of you guys tow with an L322 that was fitted with a tow bar from new?
1) Do the rear parking sensors off when you plug in the trailer plug and you select to reverse?
2) Do you have to turn off sensors each time you select reverse on the dash?
The reason for the question is I have retrofitted a tow bar and wiring plug I have told the car that a tow bar is fitted using an IID Tool but when selecting reverse the beepers are still going?
I have been in touch with Pat from Gap and he said that it cannot be done on the L322 model or the L405 up to 2017?
after that date, JLR overcome the problem from 2017 onwards?
What is your experience with towing?
I was sure with my other 2011 L322 they turned off when selecting reverse?
Post #600108 9th Jul 2021 7:16am
kevinp
I have to press the button each time I select reverse with the caravan on. Annoying!!!
Post #600110 9th Jul 2021 7:25am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Not factory fitted, but I have the same issue with a towbar recently fitted to my 2011MY. PF Jones 13 pin electrics, fitted by Indy, programmed in. THe indicator light for the trailer flashes on the dash as it should, but the sensors don't deactivate, irritating! Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #600111 9th Jul 2021 7:27am
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
not sure if the 2012 is different but I told my car via the iid tool that I had 13 pin electrics and it works perfect?
Sensors turned off little trailer on dash, may be worth trying to tell the car again 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #600113 9th Jul 2021 7:39am
rvbush
My car has been told it's got a towbar, Indy did it when fitting, but the sensors still don't turn off. Drives:
Post #600114 9th Jul 2021 7:41am
Tinman
According to Pat from Gap, it cannot be done?
From Pat? It just does not work on these earlier L322, it will always beep when in reverse with a trailer. Others have tried including us and never suceeded.
Its the case until 2017 cars. Blame LR.
You can try if you want;
I have granted you access to the complete CCF:
-Connect the tool on a computer, do not start the updater software.
-Using the mobile App, connect on the tool ''In Bootloader''
-Wait until file loading is completed
Keep in mind that 80 % of the CCF is not taken into account by the car. Also, do not change safety or critical settings which could cause issues.
Post #600116 9th Jul 2021 7:46am
Furnitureman
Pat is a top bloke and he knows more about the iid than any of us but I’m talking from my experience and it’s on the menus to select either 7 or 13 pin which I selected the latter and my reversing sensors switch off when the trailer is connected I’m sure many others will come and say the same 2012 Range Rover Westminster 4.4 TDV8
Post #600118 9th Jul 2021 7:50am
Tinman
Would that be in the CCF folder?
Post #600119 9th Jul 2021 7:52am
Furnitureman
I can’t remember exactly where it was but I’ll plug it in today and look for it 2012 Range Rover Westminster 4.4 TDV8
Post #600121 9th Jul 2021 7:58am
Tinman
Topman Thumbs Up Thank`s
Post #600122 9th Jul 2021 8:03am
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Should also stop the rear fogs coming on, on the car! Mine doesn’t also found that the options on the tool are limited to almost on or off! 2014 vogue se
Post #600123 9th Jul 2021 8:05am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
My factory fitted tow bar on a2010 turned the reverse sensors off and also the car rear fog lights.
The fog lights were not wired through a switch in the socket.
Ian
Post #600124 9th Jul 2021 8:07am
Tinman
That was what I remember now? no fog lights when plugged in?
Post #600125 9th Jul 2021 8:08am
Furnitureman
Just had a quick search and Stan posted this a while back showing the menu on the iid showing what can be turned on/off I’ll still have a play and write down a quick how to later
Post #600127 9th Jul 2021 8:11am
chefkenmore
Why can’t I get that menu on mine?
After market bar, genuine 13 pin socket and wiring loom fitted by the dealer! They had it back twice and couldn’t programme the bar electrics!, to turn off the fogs and sensors and I’m sure it should also lock the suspension in normal! 2014 vogue se
Post #600129 9th Jul 2021 8:17am
