![]() | Home > Technical (L322) > 2007 TDV8 dashboard lit up like Xmas tree limp mode |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Sounds like battery to me. Check the leads first and earth points are all tight and clean.
MH04 Member Since: 23 Nov 2016 Location: Hampshire Posts: 41 ![]() ![]() ![]() |
The battery is quite old on it, I’m in Weybridge, there’s someone I normally use for servicing etc but if you know anyone who’s really good with them I’m open to suggestions!.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
Voltage should read 14.5 volts when charging with no load, everything on and it should still be 14v, that tests the alternator...
Put a multimeter on it when running and was showing 13.99 V so I’m assuming not the alternator, new battery put on this afternoon and all seems well so far, couldn’t believe how much faster it cranked when starting, maybe my old one really was knackered, it certainly looked old. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I would keep a eye on the alternator, this sounds identical to when mine failed on a 2007. Slowly got worse over a period of months and initially felt like a failing battery. If the alternator was strong, it likely wouldn't fail mid journey even with a poor battery IMO.
Thanks, I will keep an eye on it, alternators on them aren’t that expensive from looking online but it seems like it’s a pig of a job to do!!. |
