![]() | Home > Technical (L322) > L322 2007 4.2 SC Timing Chain & Valve advice |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 934 ![]() ![]() |
Those iridium plugs are a pain in the butt, fit some standard ones and try again you don't need special plugs for lpg. |
friskydog Member Since: 16 May 2018 Location: West Midlands Posts: 70 ![]() ![]() ![]() |
What issues have you had then be interested to know.
The difference in heat from lpg over petrol has no Ill effects, iridium plugs are an expensive waste and are always going wrong weve just swopped some out on my mates xk8 , not got 300 miles on them and 1 went down swopped them for standard ngk plugs all is good again. |
Interesting...
So I had diagnostics completed on the car from a well established LR engine specialist.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 852 ![]() ![]() ![]() |
really odd that you are not getting any P0011 or P0021 error codes if the timing chain is slightly off
Yep never seen that type of code ever. Only ever lean codes. I take it you saw picture attached where the chain is hitting internal part of engine. But still no codes like the one you highlighted. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
you don't have to watch it all, but start at 12:50 into this youtube video, it talks about the M62 engine and the timing chain guides, early signs of this happening are when an error code is reported on Camshaft Bank A ( bank 2 ) Over Advanced error code ( P0021 )
I'll check them out thanks for that 👍
Bmw Tim's channel is pretty good But that clip is of no use as you have the jag engine not the m62.
Just a quick question hopefully.
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 ![]() ![]() ![]() |
Not sure what compression one of these engines should have but if yours is in the acceptable range then it would indicate that your valve seats are not warn to the extent of them leaking or them having recessed to the extent that the valve doesn't fully close. So yes I think it would indicate all is well. |
Great thanks as that will save taking my heads off which saves time and money. Excellent. Thanks for the reply. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
So two options to resolve my issues. Spark plug reseat might have solved misifre now. However remember the chains need replacing with tensioners and guides no matter what. I'm just in two minds as option 1 I might be able to afford but I am concerned that not sorting the valve seats will still minimise the life of the engine even if I do do option 1. What a choice any feedback appreciated. What would you do in my shoes? No codes coming up but with th timing chain picture actually touching the inside of the engine its clear they are slack and need replacing. Can I get away with only doing option1 or is option 2 essential due to valve wear readings?
