![]() | Home > Technical (L405) > Clicking noise when turning left |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Thank you for the part numbers. If you were on this side of the pond I'd ask if you wanted to part with them. I think I will order from FCP Euro for the lifetime warranty.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
I don't think you can be as conclusive as that. Clicking when turning is usually a CV joint. Kev
Im getting ready to order LCA's. I'm at 46k miles so its probably a good idea I do them anyway with the new sway bar bushings.
I was able to get just enough room to get a spanner on it by using a 2ft flathead to pry the back down.
Any update on the clicking, horse? Kev
All 4 LCAs just replaced plus new sway bar bushings put in a few weeks ago. THe foreard LCA were toast....I could easily move the balljoint around....the rearward facing I actually probably could have kept in.
