![]() | Home > Technical (L322) > TD6 Hot Start Issue? |
WellDrivenJames Member Since: 03 Feb 2020 Location: Cambridgeshire Posts: 44 ![]() ![]() ![]() |
The issue seems to have got worse now, as soon as the car reaches temperature it struggles to start once stopped - just turns over and over and it *usually* fires up on the 4/5th attempt but I'm worried about the wear on the battery.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
i cant help with your problem but i can let you know that there are WM downloads in the wiki which could help . ... - .- -.
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
I had this problem with my Td6. It never got to the point of being terribly bad, but if I stopped after a couple of hours towing our caravan it wouldn’t restart until it had cooled down a bit. I found I could speed up the cooling down by stripping the engine cover and associated bits around the top of the engine
Thanks for the info.
I had no issues when it was running, just impossible to start when hot. Current: 2010 Range Rover L322
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2666 ![]() ![]() |
This was my exact start point for failing injectors . Start great 1st time , then progressively got to the stage it would not start after hot. It did start to judder too , better get it looked as soon as tbh. |
Had the crankshaft position sensor fitted today, it didn't fix the issue to we did the dull injector leak off test and just as others have said, that seems to be the issue. Injector number 6 needs to be replaced so a new one is going to be ordered tonight to hopefully get fitted on Friday. '04 Adriatic Blue Td6 Vogue
