![]() | Home > General > Reliable Rangey |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 ![]() ![]() |
Thanks Merchy.
HS66 Member Since: 22 Jun 2016 Location: Surrey Posts: 73 ![]() ![]() ![]() |
Did a load of bits to my 3.6 TDV8 and it repaid me by crapping its gearbox even though oil had been changed in my ownership and before |
How much was it to replace/repair the gearbox? |
I’ve been quoted 2000-2500, just don’t know if it’s worth doing on a 4500 ish car. |
I’d check autotrader on prices when fully working, how many miles has it done?
134 with about 9 services, bit of rust in the NS rear quarter.
So is it better to get a TDV8 like the below at the bottom end of the price range and immediately spend £3-4k on replacing turbos, egrs, and transmission flush or getting a better condition td6 with lower mileage for the same outlay?
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Slow progress…..to be honest, I think you’re over worrying about the ‘perfect’ car for you.
Thanks Fox, think I needed that😀
MH04 Member Since: 23 Nov 2016 Location: Hampshire Posts: 35 ![]() ![]() ![]() |
Why on earth would you spend 5k on a car then spend thousands putting new turbos and EGRs etc on them unless they’d actually failed?.
Your last line is spot on! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
On the replacement of the turbos another poster suggested on the previous page, I assumed that if the turbo goes it can damage the engine at the same point? Therefore I guess his suggestion was better to be safe than sorry??? |
“Your last line was spot on” referred to slow progress not mh04’s post, sorry for any confusion.😁 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
If the turbos are alright then it seems counter productive to change them for the sake of it to me, personally if I were in your boat I’d get a 5k TDV8 and just run it and maintain it.
