![]() | Home > Technical (L322) > Key programming - key lost program |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
I have to reprogram my keys as they have both lost the remote function. When you say they both have to be done together is that within the same 30 sec time that the bcu is looking for codes or push the buttons on both keys at exactly the same time.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Says in the description 315MHz - American spec, or 433MHz - 315 won't work on a UK car - wrong frequency - I see they do both - but I reckon they've sent you the wrong one. |
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 ![]() ![]() ![]() |
Worked for my 2007 vogue tdv8, needed to try a several times before I got I right though. |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
Referring to the easiest way- MachineHead says to hold unlock for 13 sec than press unlock 3 times and release BOTH
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
I got my two keys refurbed by Timpsons for £30 each but only one key can do the wireless remote.
BigJon Member Since: 05 Apr 2013 Location: Adelaide - Lower Mitcham Posts: 14 ![]() ![]() ![]() |
Brilliant, worked perfectly for my new key after replacing the aerial booster in the upper tailgate. Waiting for the second new key to arrive, then it will be good to have two fully operational keys again. |
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 ![]() ![]() ![]() |
This worked for me after six months of trying.
hbthepilot Member Since: 21 Mar 2021 Location: Bludenz Posts: 33 ![]() ![]() ![]() |
Hi every one,
This will be the transponder.
