![]() | Home > My Range Rover > ‘Massive Car’ my 07 Tonga Green TDV8 Vogue Experience... |
Chapeau! Velo Member Since: 22 Jul 2019 Location: Down South Posts: 115 ![]() ![]() ![]() |
Well, it’s in the garage again. This time to sort the air con out. Apparently, when attempting a recharge, the heat exchanger had a leak and the replacement that I supplied to do the job was faulty. The garage have ordered a genuine part so hopefully that will solve the problem but we will have to wait and see. Hopefully it’s as simple as claiming for the refund on the faulty part (labour fitting charge too) when I get it back. |
Well the car is back with air con working. The original heat exchanger / rad was faulty and within a min of re-gassing the system, post refitting a new red, a vacuum was pulled so all good. Now I just need to send the duff part back and claim the labour from them as well. |
Well, almost another year on (where does it go?) and I’m pleased to report that nothing major, except a LHS engine air inlet manifold, has needed replacing.
