Home > Technical (L405) > L405 2013 Adaptive cruise control not working |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 584 |
Probably not be relevant, but I'm still having intermittent issues with my radar. I get the message "Radar Blocked - IEB not working". Once that's occurred I cant engage cruise. Its fine if I remember to engage cruise before I get the message and then turn off the adaptive bit. I can then switch in and out of cruise. But not once that message has been displayed. Happens about 1 journey in 3. Since you don't mention the radar blocked message its not likely to be your issue....but have you checked the radar with your IID? Mike - MPx
21st Jun 2021 10:24pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Does forward alert work? |
21st Jun 2021 10:27pm |
Hzwart Member Since: 19 Jun 2021 Location: Mpumalanga Posts: 7 |
I have this fault
22nd Jun 2021 5:34am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1195 |
I had a similar issue which was caused by air compressor issue.
22nd Jun 2021 9:12am |
The fault on the pcm does not reset.my questions where is this coming from. ABS and wheel sensors. What wheel sensors are used for this.
22nd Jun 2021 3:45pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
The ABS ecu derives the speed signal from the wheel ABS sensors and broadcasts the derived speed as a message on the high speed canbus. The radar unit connects to the HS canbus so could be the real source of the fault code. I would try removing the radar unit's fuse or disconnecting the battery for a few moments then see if the fault code still occurs. The radar unit has permanent 12V power as well as an ignition feed so switching off the ignition doesn't cause the radar unit to restart.
22nd Jun 2021 9:25pm |
I have tested forward alert today.it works but setting it at maximum distance, the actual car gap is only one car length at 120km\h. Did I loose the calibration maybe.
23rd Jun 2021 2:38pm |
Hi GreameS
23rd Jun 2021 2:47pm |
That was only relevant to the BMW made 02-06 model years sir… So, totally irrelevant for your model 👍 |
23rd Jun 2021 6:29pm |
Thank you |
23rd Jun 2021 6:52pm |
I don't have a wiring diagram for any L405 and my 2014 RRS fuse information doesn't show a fuse for the radar unit, but LR's documentation for my MY12 L322 is far from complete. However the fuse information inside the lid of the engine bay fuse panel should show the radar unit's fuse.
23rd Jun 2021 8:57pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
My intermitent ACC issue was resolved by cleaning and tightning the megafuse block, so check on the 12v supply side. I has been reliable for me since.
25th Jan 2022 10:45pm |
Good day
26th Jan 2022 8:53pm |
