Home > General > Reliable Rangey |
Zerosumgame Member Since: 27 May 2021 Location: Petworth Posts: 45 |
Is the bill for a pair of new turbos on the 3.6 TDV8 really £4500? I am currently looking for one but was assuming more like £2k...may have to have a rethink! |
21st Jun 2021 5:24pm |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 |
http://prestige-german-engines.co.uk/range...o-failure/
21st Jun 2021 5:37pm |
Hmmmm....and what is the consensus on when these generally start to let go? 120k miles? Anything that can be done in terms of preventative maintenance? Blanking the EGR's? Very short oil change intervals (like 3k miles?)? |
21st Jun 2021 5:42pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
You said at your price point a 3.6 will need turbos within 12-18 months… I don’t think this is correct, turbos can go at anytime/ mileage so age or odometer reading has little to no bearing. You might find a 3.6 with new turbos or get one which will never need turbos.
21st Jun 2021 5:55pm |
Not seen a quote of £2.5k or less to fix, if it is that then I’d be tempted that direction as you’re trading turbos for gearbox replacement costs.
21st Jun 2021 7:15pm |
Not really… both the TD6, 3.6 and 4.4 can have gearbox failures and turbo failures, you are not trading one issue (budget) for another, they all can have the failures and the older, high mileage vehicles will obviously be more prone to issues as there’s more chance of poor servicing, neglected and lack of mechanical sympathy from multiple owners.
22nd Jun 2021 6:45am |
Perhaps. Turbos, egr’s gearbox flush etc is on top of purchase price so we’ll see what budget allows come March, assuming used car prices come back down as chip manufacturing starts getting going again.
22nd Jun 2021 12:50pm |
Doing both the turbos and egr’s shares work and should work out cheaper, I would do the intercooler hoses, drive belt, pulley’s and tensioner plus alternator at the same time unless they have been replaced already.
22nd Jun 2021 1:14pm |
There is a danger from this!
22nd Jun 2021 5:52pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
I fully understand a potential buyer of a FFRR carrying out a lot of research before buying one, you obviously have more sense than me.
22nd Jun 2021 6:51pm |
Thanks Merchy, I’ll get there!
23rd Jun 2021 1:00pm |
Good afternoon Slow progress
23rd Jun 2021 1:37pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
I have had a td6 and now a 3.6 tdv8. The td6 was a nice car (until it was written off!🥴). The 3.6 is a much different and far better car to drive. More get up and go. Better gear box.
23rd Jun 2021 1:47pm |
Had something similar with my grandfather before he passed away. Every week it would have a flat battery, we replaced the battery multiple times, had an auto electrician look it over and couldn’t find anything. Then after speaking with him one day he nipped out to the garage….turned out he was starting the car every day to check it worked then turning it off after a minute!!!!! Good luck with your mum’s car |
23rd Jun 2021 5:48pm |
