![]() | Home > Maintenance & Mods (L405) > strange whine |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 246 ![]() ![]() ![]() |
Could be a split turbo hose? Sounds like when you plug a blade of grass between ur hands and blow?
aguiness Member Since: 13 Jan 2021 Location: glasgow Posts: 36 ![]() ![]() ![]() |
Its going in on the 16th for a service and also the oil sensor in the sump issue ill get them to check thanks |
Is it anything like this?
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16318 ![]() ![]() ![]() |
The diffs can condensate and then the main bearing can whine under load... Have you ever checked the oil condition? |
I havn't checked the oil yet. you dont hear the noise when free wheeling only when the accelerator is pressed and driving. |
Exactly… |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8720 ![]() ![]() ![]() |
Sounds like diff or driveline whine to me too. Had the same problem in our old hilux, diff whined under load, then squealed, then made horrid noises. New diff required, so a quick change of diff oils and see how it goes. There is nothing that can't be fixed with a hammer😜😜
Great thanks |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
Any update? My 5.0 SC whines between 70 and 75 mph when applying power. Not at any other time. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
Hi
