Home > Technical (L322) > TDV8 4.4. rpm occasionally drops out (8th gear)
roel2018
Belgium 2011 Range Rover Vogue SE TDV8 Santorini Black
2011 TDV8 4.4. L322
150.000km / 93,250 miles
Hi guys,
For some time I have problems with the TDV8 4.4. 448DT engine. Can't find an existing topic here or using the wrong key words... When driving 120 km/h (60mph) on the highway, the rpm occasionally drops out intermittetly. Stuttering once in a while. Occurs in 8th gear. As soon as I use the S position and switch manually back to 7th gear, there is nothing wrong. There is also nothing wrong if I go above 140-150 km/h (90mph). It seems that a part or sensor is getting the wrong signal and that the signal is interupted for a second. Can't find an error in iCarsoft LR V2.0.
What could it be? I am thinking of:
- Camshaft sensor (had this before with a 1999 BMW 528i, same feeling)
- Crank position sensor (had this before with a 1999 BMW 528i, same feeling)
- Something with the diesel supply (changing fuel filter but don't think this is the problem)
- Air mass meter (but then the problem must also occur with other gears/rpm and that does not happen)
Before I replace all these parts, anyone had an idea or the same problem?
Notice: ZF Service changed the oil last week. Everything was perfect.
Post #546885 12th Mar 2020 9:09am
TomCobbly
Could be this
https://www.fullfatrr.com/forum/topic38291...hesitation 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #546886 12th Mar 2020 9:15am
Baltic Blue
I put up with what I described as a cough at 75-80 mph, but the dealer did the mentioned TSB software update a few years ago and it completely cured it. Been fine ever since.
Post #546888 12th Mar 2020 9:30am
roel2018
Thanks for that. I will go to the local LR shop to check if LTB00454v2 is updated in my one. When was the technical bulletin published? Update: 11-May-2012
Maybe they can also check if the crankshaft position sensor is logging errors interuption for the last month. I have red about that subject but can't find it again Confused
Post #546890 12th Mar 2020 9:40am
roel2018
Today I was at the local LR workshop. My RR was not updated with LTB00454v2 so they runa diagnostic test. No failure was recognizable/logged, no failures for the crankshaft position sensor so that saves me a little €500 (446 pounds). The update cost me € 64 (57 pounds) so hopefully my problem is solved...
To be specific:
They re-programmed the PCM (Powertrain Control Module, part LR023239) with the newest software (LTB00454V2).
Technical bulletin LTB00454v2 says it will solve the problem when driving between 60 mph and 90 mph, with an ambient temperature above 10 degrees and in 6th, 7th or 8th gear.
Post #554518 19th May 2020 8:39pm
DrRob
Keep us posted Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #554521 19th May 2020 8:44pm
roel2018
Ok. Last year my fattie was updated with LTB00454v2 but yesterday it happens again twice! So, i think i need a new CPS Crank Positioning Sensor....
Post #598241 21st Jun 2021 10:05am
