Home > Maintenance & Mods (L322) > So what’s this then?
Clobski
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Baltic Blue
Hi everyone.. I’m a newbie to the site, and was after a bit of advice.. I have just brought my first Range Rover (a 2010 4.4tdV8 Autobiography Very Happy ) and am still in that WTF is this phase.. So I was just underneath the car today taking off the Side Steps that came with the car when I noticed a long (rusty Big Cry) cylinder sat up in the floor pan, right along the driver side sill. Can anyone tell me what it is? And also if it is expensive to replace because it felt very rusty!! Thanks for any advice.
Post #598172 20th Jun 2021 4:50pm
air storage for the suspension.... ... - .- -.
Post #598174 20th Jun 2021 4:55pm
Clobski
Cheers Stan.. any ideas if they are easy to replace???
Post #598177 20th Jun 2021 5:04pm
not personally but a forum search or perusal of the WM might give you some idea... ... - .- -.
Post #598178 20th Jun 2021 5:13pm
Some have replaced them, but they are a pressure vessel, so if it’s not leaking and the suspension is working then a quick clean up and repaint should suffice. There is nothing that can't be fixed with a hammer😜😜
Post #598179 20th Jun 2021 5:15pm
Clobski
Post #598181 20th Jun 2021 5:24pm
DrRob
If it ain't broken then don't fiddle Laughing
Wire brush, Kurust then some metal paint Thumbs Up
I use https://www.diy.com/departments/fortress-b...969_BQ.prd Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #598183 20th Jun 2021 6:01pm
Clobski
Thanks Dr Rob.. it’s just that as I was spannering off the side steps I kept brushing against it and it felt like paper mashe!!!.. I just remember having an MGB GTV8 a few years ago that had stainless sill guards.. when I took those off the lower body underneath felt the same and was rusted through. Big Cry But I guess if it’s a pressure vessel (and the air sus is working fine) then it must be sound.. just couldn’t work out what it was.. as you say.. don’t fiddle.. Very Happy
Post #598187 20th Jun 2021 7:01pm
DrRob
I see you’re just up the road from me. Happy to help with anything local e.g. I use www.glenrands.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #598190 20th Jun 2021 7:21pm
Clobski
Fantastic.. thanks Rob.. just about to book myself onto a days worth of off-road training on Hankley Common.. which is just up the road from you.. so bound to need some advice after that.. appreciated 👍🏻
Post #598194 20th Jun 2021 7:53pm
bluebottle
United Kingdom 2012 Range Rover Vogue SE TDV8 Buckingham Blue
Ah, another nearby. Any chance of organising a working meet where us new FFRR owners can get some assistance in the little jobs we all should be doing, like sill and rear wheel arch protection?
I’ll bring doughnuts! 2012 L322 TDV8 Vogue SE: Buckingham Blue
2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten
Post #598200 20th Jun 2021 9:13pm
Re: So what’s this then?
I change LOTS of them that rust through and cause brake downs! Early early cars had aluminium tanks and then JLR decided to change them to steel! So, the moral of the story is... If it feels REALLY REALLY rusty then change it before it leaves you stranded sir Thumbs Up
Post #598216 21st Jun 2021 12:00am
Clobski
Yes good call Mr Craig.. will have a gentle poke.. will I need any special kit.. ie is it a diy job? 2010 RR 4.4tdV8 Autobiography
1966 Series 2A 2.25 Petrol SWB - Sold
Post #598252 21st Jun 2021 11:34am
Merchy
Working under a vehicle, especially with rust particles flying around - ALWAYS use eye protection.
The below link will give you and idea of what is entailed, it can be a bit fiddly but doable at home. Thumbs Up
Not the best video, but it will give you a good idea.
Post #598265 21st Jun 2021 1:06pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I did mine on the drive. Wasn't too bad though I recall being a bit confused by whatever set of instructions I was following. There is high-pressure air involved so make sure you de-pressurise the reservoir safely (I used my IID Tool) and make sure you support the vehicle on axle stands securely. Access to a couple of the bolts was a little tricky IIRC but overall it's a pretty straightforward job. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #598267 21st Jun 2021 1:34pm
