Home > Technical (L322) > Help Please Newbie here |
44ark Member Since: 01 Apr 2011 Location: faringdon oxon Posts: 58 |
Hi guys
11th Apr 2011 8:01am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Can't help specifically with all the issues but do you know how old/good the battery is. They have a habit of throwing random error messages when the battery is low on voltage. Worth a check first before heading down potential "blind alleys". Ash
11th Apr 2011 8:22am |
no idea on the battery but at a guess its the original one it does seem strange that after starting the car leaving it a few mins turing it off then back on again fixes the problem and errors are then no longer shown on the car only the coolant check one so it could be the battery i guess. |
11th Apr 2011 8:53am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
The check coolant isn't a level issue. They use a probe to check the density of the fluid. You prob don't have enough coolant in the mixture. During the winter when my bat was low on juice it would through up the air suspension, HDC faults due to low voltage. If the bat is old worth investing in a new one as the car has so many ECUs and uses so much power a dodgy bat can cause ghost errors. |
11th Apr 2011 11:45am |
Worth remembering that not only will it bong if there is not enough AF in the mix, but also too much as the weight will swing in the opposite direction. Personally I've had to replace two sensors due to them being faulty. |
11th Apr 2011 11:57am |
ok thanks guys will post up an intro and hello in mo too |
11th Apr 2011 12:05pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
I had a gearbox fault come up in mine, but it was a genuine fault fixed by changing ATF. I would say your symptoms sound 100% like early signs if battery failure. You can look on top of the battery at the indicator cell, should be green. After 5/6 years you'll be due a new one though if you're on the original!
12th Apr 2011 7:46am |
