![]() | Home > Maintenance & Mods (L322) > Throttle Body replacement on 2011 4.4 TDV8 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1300 ![]() ![]() ![]() |
Interested in why you're putting a new throttle body on. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Me too. Was it not working properly for DPF regen ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
When I did mine it was plug and play.
MTG2020 Member Since: 24 Feb 2020 Location: Caerphilly Posts: 35 ![]() ![]() ![]() |
It is because this was my last hoe to cure the "Restricted Performance " issue as per my previous post.
Interesting Richard. Mine shuts down quietly but I do have the Kangaroo juice now and again. Dare I take the throttle body off and look at the gears. Don't want the screws snapping on me!! |
Kevin
My bolts came off really easily when I replaced the inlet manifold, a few weeks ago.
MTG2020. I was on about the screws on the plastic cover over the gears mate.
Whoops! Okay. No you have to buy the "O" ring seal separately. Cost me £1.80. The Throttle Body cost me £158.00 including VAT. Looking around, this was a good price, but for the sake of £1.80, you would expect JLR to include it. |
Kevin
Hi Kevin. Replace the Throttle Body, it's made no difference at all. |
I am now in in the process of replacement EGT sensor. This is definitely nackered, there's a code for it. Hopefully, that will cure all the RP issues because it has caused DPF regeneration issues, which will result in RP. |
