Home > Maintenance & Mods (L322) > Super Charger bearings and coupler
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Eaton m112
Mine starten to get noisy at 240k km.
There was a lot of play in the coupler that I could feel at the pulley.
So hopefully this was the only problem, just the coupler. Yeh sweet dreams!
Last week I took the SC of, not a to difficult job but time consuming.
And there is no need to take the coolant cross-over pipe of or any ather
coolant hose.
take of;
- engine cover, air intake pipe and the alu air intake. Just hose clamps.
- the main coolant fan, remember anti clockwise!!!
- release the SC beld
- take of the rubbers between the SC and the aircoolers and take of the
pressure manifold.
- than the trottlebody, 4 bolds
- after that the elbow, thats a little thight and a challenge. 4 bold T40
the bracket under the elbow, thats simple
- take of a few vacuum lines, if you are there you see witch ones
- than, at last, you can take out the 3 bolds holding the SC
- than if you hold the aft of the SC high, you can wiggel the SC out and the
pulley wil just pass underneath the cross-over.
here are a few pic's to show you whats involved
first the pressure manifold and the rubber connections
air intake manifold
than you can check you 2 cooland hose that run under your SC
When the SC is on the bench, let the oil out via the plug and take of the snout. Inspect the
coupler, mine was very worn, and check the bearings for play. Mine bearings were oke
except for the needle bearings in the back.
the original coupler
Because I could feel some play in the 2 lob spindles I took the aft part
also of to get to the needle bearings.
By the way, this is the new coupler
And you can see some damage on the lobs due to the worn needle bearings.
This is one of the two needle bearings and her cap. You can tap the caps of
simple from inside out/
Then pull out the bearings, I do not have a press, so I did it with a
treaded rod and nuts. Like this.
Than, when the are out, I make a giude to pull te new bearings in please, also with the
threaded rods, and pull them just 0,1 mm under the SC house on the inside.
Tap the caps back over the bearings on the aft.
Put the SC back together, and your done.
Using a very little silicon gasket on the surfaces between the part of the SC.
Dont fotget to put the oil back, and tommount the SC back on the engine. Job done.
all the spelling faults...............you know
Post #597646 15th Jun 2021 7:42pm
dhallworth
That's a nice guide Smile I think mine are on the to do list this summer when I get a chance as prevention is better then cure!
Post #597657 15th Jun 2021 10:16pm
dingg1
Good guide Thumbs Up
Post #597658 15th Jun 2021 10:49pm
