Home > Maintenance & Mods (L322) > Oil leaking down N/S/R of engine
DaleL322
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Hi guys,
Since owning my 3.6tdv8 L322 I have noticed a leak from the N/S/R of the engine which has been getting progressively worse recently
Initially I suspected the front differential output seal, however after thoroughly cleaning it down and doing 200 miles of dry driving it appears it's not that seal, but coming from above the differential and leaking down onto the heatshield and being spread by the driveshaft
So far I am struggling to pinpoint it, there is fresh fluid collecting on the underside but I've not been able to find the actual source of the leak.
I have a suspicion that it may be coming from the transmission cooler pipes, is this something anyone has dealt with before, does it sound familiar?
Thanks in advance for any help Thumbs Up 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
https://www.fullfatrr.com/forum/topic58777.html
Post #597435 14th Jun 2021 10:17am
If it's gearbox fluid it will be either red or straw coloured and should still have a colour and not look like blacker than coal engine oil... Thumbs Up
Can't help with where from, usually clean the area fully, take it for a short drive and have a look.... Pete
Post #597474 14th Jun 2021 2:17pm
DaleL322
Hi Pete
I have come to the conclusion it's transmission fluid, just wasn't sure if gearbox or front diff initially
Going to bring it in to work tomorrow and start stripping it down to find the source, I am suspecting the cooler or cooler pipes at this stage 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
Post #597477 14th Jun 2021 2:37pm
Good Luck.. Pete
Post #597490 14th Jun 2021 4:13pm
