![]() | Home > Maintenance & Mods (L405) > L405 Bike Rack Options - 4 bikes? |
So far, weight of the bike carrier is showing 20.9kg (manual says says it should be 14.5kg)and 3 (not 4 bikes) showing a combined total of 90.9kg… surely a RR with a factory fit Towbar can cope with a Halfords bike rack and 4 standard mountain bikes… |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
In pure weight terms it's fine, but it's the way the force is applied that's the challenge. A trailer will flex on the ball, whereas a bike rack won't so it's acting like a lever. That is why the spec is lower for bikes vs a trailer that can have a nose weight of 200kg.
Ifor Williams ![]() I've had 2 - a flat bed and a box van - both have been absolutely fantastic to tow. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
I thought bike rack - make my own, how difficult can it be. Not quite from scratch as I needed to cannibalise a tow ball clamp from an old rack. Worked fine bike only fell off twice (well down actually, wheels remained fastened to rack) only slight damage to bike and additional strap fitted to rack to prevent repeat of bike falling - so far so good. Another of my engineering triumphs 😩 Geoff |
TomV8 Member Since: 25 Sep 2017 Location: Yorkshire Posts: 107 ![]() ![]() ![]() |
MonkeyMan, another suggestion for a hardtop camping trailer:
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 ![]() ![]() ![]() |
Thanks for all the trailer suggestions, wisdom shared is greatly appreciated.
Could have just edited my last post full of poor maffs but… all my mistook. Got the arithmetic wrong.The weight of the carrier and 4 adult size bikes is all coming in at less than 80kg which, as per Alistair’s post, is also the maximum nose weight for our car too (in respect of putting a bike carrier on the factory towbar). Moral of the story is wear your spectacles, don’t rely on a rubbish calculator; and just use a pen and paper to do the rithmetic 🙆 The purchase remains a good piece of kit and good vfm ![]() |
We managed to try the ‘new’ carrier this afternoon. Very sturdy piece of kit, very slick/ easy to connect onto the towbar and felt very secure when being driven with bikes on it 👍🏻
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Ryan, as you aren’t using the grey socket for the rack, there is a smaller converter available which just does the black plug to 13 pin.👍🏻 There is nothing that can't be fixed with a hammer😜😜
Thanks, was lucky enough to be able to borrow the double adapter but for it to fit requires removal of the plastic cover that surrounds the towbar because the double adapter is otherwise too bulky to fit on. 👍🏻 |
I use one like this. |
Ordered Mark, cheers 👍🏻 |
