Home > Wheels & Tyres > Best 22" tyres
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
They have plenty of tread left… but haven’t looked at the pressure. They looked ok, but to be fair they could be under inflated. That’s a good shout!
The noise I am hearing seems to be coming through the car rather than from outside. Other cars coming past are quiet so the double glazing is doing its job well. My thinking about the bushes is they isolate the wheels from the arms, which are then Isolated from the body. If they are worn out or solid then some noise *could* transfer through???
Regardless the bushes are on the list, as are the tyres (when worn). Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #596516 5th Jun 2021 3:10pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Well took it for a 100 mile drive from Bristol to home last night and to say how much more quiet and comfortable the ride is an understatement. Totally transformed the car. I know some say they find the Hankook a very noisy tyre, I don't find that at on mine but then I guess I'll just have to wait until they wear down and see for myself. Be interesting to see what kind of mileage I get out of them.
Ffrr lover, let me know how you get on when you get the bushes done see if it takes away the road noise you are getting.
Post #597246 12th Jun 2021 12:35pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
What size did you go for?
Dave 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #597260 12th Jun 2021 8:24pm
Barmybrummie
Hey Dave I stuck with the 285/35/22 as that was the only ones they had in stock and needed them rather urgently. And got them for a real good price so I'm not complaining.
Post #597283 13th Jun 2021 8:37am
Dave G
Thanks, will bear that in mind when i come to replace mine Bow down
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #597356 13th Jun 2021 6:48pm
RosieL322
Just for reference, I have Davanti tyres on mine. Didn’t buy them, it came with them and under £400 for full set. I thought they would be awful but I’m actually surprised. They do howl on poor road surfaces but ride is fine. Grip doesn’t appear to be an issue in a 2.7 tonne, four wheel drive tank in most conditions. I will be changing them to a premium brand when they wear out though. I have a rubber brand fetish… 😂
Post #597574 15th Jun 2021 10:46am
Ffrr-lover
So no bushes have been swapped yet, but while “popping” a parking sensor back into the front bumper I did notice something…
I seem to be missing the plastic shielding under the car! Could this make a difference to the noise travelling into the car???
(There’s also a bit of rust that needs to be taken care of… Big Cry ) Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #598151 20th Jun 2021 12:42pm
RosieL322
*Update*. Had Rosie in for a cv boot and the garage noticed a cut in one rear tyre and cords showing on the edge on another! Two new tyres require now. Wanted to know opinions on the 265/40 option rather than the 285/35. Anyone run this on 22’s?
Post #598247 21st Jun 2021 10:58am
Barmybrummie
I would say that's a strong possibility there ffrr lover. Driving along at speed you are going to get a lot of wind rushing underneath and going into the gap where the shield should be causing drag and wine noise I should imagine. Like I say, mines very quiet since tyres changed.
Rosie, further up this post bronjen and Craig did mention to run on 285/40/22's as give better comfort and ride and more protection against damaging the wheel if you hit a pothole. I didn't go for the 40's as I needed tyres urgently and got them really cheap so stuck with the 35's. It's your call. Though it's strange you also had a cut in your tyre too,I wonder if this of concern running 35's as I had a nasty cut in mine to and was badly worn. Let us know what tyre you put on and if any difference to ride comfort etc etc.
Post #598294 21st Jun 2021 5:26pm
Bronjen
United Kingdom 2002 Range Rover Autobiography 4.4 V8 Baltic Blue
In reply to your question would suggest using 285/40/22 or 275/40 22 tyres.
the 35 profile side wall is too short and you have to use very high tyre pressures to stop the tyre carcass moving on the rim due to the weight of vehicle
40 profile gives better stability of the tyre due to the taller side wall and gives a bit of cushion to the wheel when going over large pot holes, most of the cracked 22 inch wheels had 285/35/22 tyres, just look at all the 22 inch wheels for sale on ebay that have cracks or have been repaired, whereas 285 or 275 40 series tyres seem to protect the rims from pothole damage and may also save the rim edge if you caught a kerb
Hope that helps Thumbs Up
Post #598296 21st Jun 2021 5:36pm
Ffrr-lover
So a quick google suggests the missing part is only £80 new which isn’t bad. I plan to sort the front bushes in the near future and I’ll look at replacing it them. Hopefully it’s just a new shield and a handful of screws and clips and nothing else preventing it’s replacement. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #598374 22nd Jun 2021 1:40pm
Ffrr-lover
Im on 35’s too and when I hit a pothole my tyre had to be replaced due to a cut in the tyre wall?!?! It would appear that this might be a common problem…
I’m definitely trying the 285/40’s on the front when it’s their time… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #598376 22nd Jun 2021 1:43pm
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I had 285/35/22 on my wheels for a couple of weeks when first fitted & they were awful & the ride was terrible for a Range Rover. When it went for MOT we noticed that at the back they had cracked under the weight of the car and still had 5mm on them.
I whipped them all off & got a full set of 275/40/22 Pirelli Scorpion verde. It made a massive difference, the ride was just like a Range Rover should feel, no more banging into pot holes & cringing. Quiet & smooth again & they wore really well, in fact never had a tyre that lasted so long & on such a heavy car. 2004 RR 4.4 V8 Autobiography
Post #602232 29th Jul 2021 7:44pm
