Home > General > Reliable Rangey |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
As the other components are mostly similar, this is down to the engine / gearbox...
11th Jun 2021 7:40pm |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 784 |
If we’re playing the sample of 1 games…..Post 2018 4.4SDV8, had mine for 12 months and 12,000 miles next week and no issues at all, not even an infotainment glitch. MY23 Panamera E-Hybrid
11th Jun 2021 8:50pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Cracked manifolds Turbo drains Failed hoses between manifold Failed plastic fitting in top hose Aux belt tensioner Exhaust sensors on manifold Fuel pump wiring Rust, lots of rust everywhere including subframes, fasteners etc Reliable Rangey = mutually exclusive BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
12th Jun 2021 4:45am |
Yes, but rust is an issue on all of them, and the other bits are not major and wouldn’t make you wish you’d bought one with a different driveline.
12th Jun 2021 9:09am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1207 |
Saw Martin2's comments, which is what I would expect from a car that age / mileage.
12th Jun 2021 10:48am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
My 2002 4.4 V8 is one of the most reliable cars i've ever owned.
12th Jun 2021 12:12pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
I believe my 2008 (2012 build) black l322 is the most reliable Range Rover it has never once broken down, need repair or warranty or even a service, never a foot wrong. I cannot ask more of my Escala 1:24 scale L322 😇 |
12th Jun 2021 6:35pm |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 |
It does beg the question if the cheapest 4.2v8 is therefore best value for money at the moment. As it’s the most reliable, lower tax pre 2006, offset by fuel costs?!? Unless you have the cash to outlay on a 4.4TDV8, or you can make a TD6 gearbox last longer!
13th Jun 2021 6:37am |
Also Merchy I never think of the td6 as “lite” it’s for those of us not in a rush…if only the gearbox could be improved or switched out I’d have one! The engine sounds like a solid one just a bit underpowered for the weight of the vehicle. |
13th Jun 2021 6:49am |
Sonax do a kit that will sort the gearbox, involving strip down and machining to sleeve the soft aluminium that wears, but as cars reduce in value, it’s prob not economical to do. I think some gearbox rebuild specialists offered boxes with the kit fitted if I remember right.
13th Jun 2021 11:25am |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 284 |
I’m only a year into ownership and on my second, I only changed my 3.6 as I found a really nice low mileage 4.4 and it became apparent I was going to be doing more miles this year.
13th Jun 2021 12:39pm |
Interested if there are any links td6 gearbox mods in addition to Sonax, and who does the upgrades? (Not me!) |
13th Jun 2021 1:48pm |
https://www.fullfatrr.com/forum/post277782.html
13th Jun 2021 1:58pm |
Thanks I’ll investigate that, I think budget will be £7.5k all in, but that includes any immediate jobs!
13th Jun 2021 2:36pm |
