Home > My Range Rover > My new (to me) 2009 TDV8 L322
verydisco
Argg! it si still hard to tell on these pics with all the reflections and dirt. Big Cry
in a nutshell, if the backgrounds are grey - as in 'primer grey': they are the original lights
if they are glossy black, they are 2012. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #597053 10th Jun 2021 1:17pm
mjdronfield
The rears look grey to me.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #597056 10th Jun 2021 2:17pm
verydisco
indeed, it's harder to be positive on the headlights though.
nice looking 322 anyhow Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #597061 10th Jun 2021 3:11pm
Sandman77
A quick update on my L322 journey.
Shortly after getting the car I was greeted with an Adaptive Dynamics Fault. After checking the wiring to both front sensors I plugged in my iid tool (bought from a forum member) and found a fault with the rear left height sensor. Ordered a genuine LR replacement and my local garage fitted it for me (I couldn’t remove a rounded out bolt) and the fault is cleared. Back to being fully operational again.
One other small issue is that on 2 occasions I have had really back crackling and popping coming from what sounds like all or at least most of my speakers. The issue has gone away on its own on both occasions but I suspect the fault is with the amplifier in the rear compartment. I have read about moisture causing issues in there so stripped out the area and it was bone dry with no sign of ever having been wet. I removed the plugs from the amplifier and they were all clean with no corrosion at all. I guess I will keep my eye on it and if the issue returns I’ll replace the amp with a tested used unit.
The only other thing worth mentioning is I have ordered a new key from Aliexpress. I only have one key at the moment and want a spare. I ordered the newer smaller type which I hope I can program to my car (it is the start button model I have). It was only about £20 delivered including the blade cut to match my existing so worth taking the chance. I’ll update once the key arrives to key you know if it works.
https://www.aliexpress.com/item/1005002212...4c4duo9Wci
Post #600485 13th Jul 2021 12:40pm
Sandman77
My wedding anniversary today and my lovely wife got me the Land Rover umbrella that fits in the centre console compartment next to the maglite. Just need to find a nice pen for the other space now.
Post #600775 15th Jul 2021 4:08pm
Sandman77
My new key arrived from China today so only 11 days since I ordered it. Seems well built and of good quality. The key came cut to match my existing and works in the locks as expected.
Programming the fob to my car was a bit of a faff using iid tool and after getting a failed message a few times I thought I had wasted my money (all £20 of it). I needn’t have worried though as I persevered and after about 6 tries the pairing was successful.
All in all it was £20 well spent.
Post #601454 22nd Jul 2021 9:13am
