Home > Technical (L322) > Dreaded Suspension Fault
longd
2012 Range Rover 4.4tdv8 110k miles
I was driving along and got bing... orange suspension failure warning, drove home and the next day I started the car and it had no warnings
After 5 mins of driving the warning light came back on I checked the 4x4 screen and it shows the front drivers side flashing red, the car raises and lowers to all positions no problem. its all level but will drop to the bump stops if I leave it a couple of days.
it is now showing two faults on the screen-
1) SUSPENSION FAULT
2) ADAPTIVE DYNAMICS FAULT
No matter what position the vehicle is raised to the 4x4 info screen flashes red for front right drivers with the level sowing it lower than all 3 (please see attached pics)
I assume that its the airbag that needs replacing but I have taken the wheel shroud off and put it in off road heath and spraying with soapy water can't seem to hear or see any obvious leaks , I don't have a fault code reader, I have it booked in to be scanned on Wednesday to check the faults but ideally id like to get the parts ordered asap as I'm using my wife's Yaris with no aircon !!
any help or suggestions would be fantastic
regards
k
Post #596962 9th Jun 2021 4:18pm
have a look at the wires on top of the suspension struts...loads on the forum re this. ... - .- -.
Post #596974 9th Jun 2021 5:19pm
longd
Popped off the couple of torx and checked the connectors all good !
The lower suspension bushings have some play in them and will need to be replaced could this throw up the faults ??
Which fuse will disable the auto levelling ?? I'd like to disable the auto levelling and see if any of the airbags drop? I'm assuming the front right will drop?? if so then its obviously the airbag...
I am curious would a faulty sensor enable the car to drop the bump stops ??
I can see the below fuses cover the air suspension but can't figure which one is the auto levelling
fuse 10 in passanger compartment 5amp?
fuse 5 in bootspace 20amp
fuse 13 bootspace 5amp
thanks so much for the help so far
Post #596976 9th Jun 2021 5:43pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Height sensor failure? 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #596977 9th Jun 2021 5:49pm
longd
Im getting to think that is the fault I'm just reading up on how the system works, I guess ill just disconnect battery measure height of all 4 corners, check tomorrow if all 4 corners are the same then the only thing it can be is a faulty sensor I imagine will go out and play around with the wires connecting it etc
Post #596986 9th Jun 2021 6:16pm
longd
GUYS looks like it was just a dirty/ loose connector to the front right hight sensor ! don't want to jinx myself but disconnected batter, removed the sensor cleaned and blew it out and reassembled and no faults and is now showing all wheels level !! thanks so much for the suggestions Smile
Post #596991 9th Jun 2021 6:46pm
longd
Well that was short lived, went for a spin fault is back again, I have raised suspension to off road and have disconnected the battery I've measured the height of all corners,
will measure and see if I've lost any height over night and hopefully that will confirm or deny air bags,
hopefully its just a new hight sensor needed, fingers crossed, is there anything else I could be checking ?
Post #596995 9th Jun 2021 7:26pm
