Home > Duckworth Parts > Detachable tow bar key (L322)
Sandman77
Hi, I have just bought a 2009 L322 but I didn’t receive the key for the detachable tow bar. The lock has a 3 digit code on it. Can you supply a replacement key from that number?
Thanks
Post #596638 6th Jun 2021 5:30pm
The RR Bandit
United Kingdom 2011 Range Rover Vogue TDV8 Zambezi Silver
I got mine off eBay when I bought a RR with no key. Search it and then there’s usually an option tab I believe. I bought one then got another one cut as a spare 👍 2011 RR Vogue 4.4 TDV8
Post #596640 6th Jun 2021 5:59pm
Sandman77
Thanks but would you believe it - I had a good rummage around under the boot floor and found the key. Couldn’t get it into the lock at first but plenty of wd40 and wiggling the key back and forth and I finally got it to go in and turn freely.
Anyway all sorted now. Thumbs Up
Post #596667 6th Jun 2021 10:39pm
garth@internet.is
Iceland 2006 Range Rover Vogue Td6 Buckingham Blue
I have a 2006 MY L322 TD6. I hate to have the tow ball installed when it is not in use, as it sticks out like a sore thumb. From day one of my ownership,which is almost 16 years now, I´we maide it a routine to remove the towball when not in use. It take me less than 30 seconds to install or remove the tow ball. This includes removing it and/or replacing it to the storage. I am not joking. I've timed it!! Smile
Post #684556 1st Feb 2024 6:42pm
