Home > In Car Electronics (L322) > Rattle from front speaker itself - repair or replace?
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Since my car arrived I’ve had a rattle in the front near side lower speaker. It’s only noticeable with songs with plenty of bass as it’s normally drowned out by the rest of the music. Unfortunately there’s a few songs where it really shows.
“Not to worry, it’s probably a lose clip or wire and an easy fix”!
After battling to remove the door card (that middle clip was a struggle for me) and removing the speaker, I find that it’s the speaker itself that’s rattling. I’m holding the speaker in my hand with music playing and I can hear it rattling inside (only music, nothing if I shake it).
I notice there are some additional screws around the cone, but they are partially obscured. Is it possible to break down the speaker? To locate the cause of this rattle? Or am I better off simply buying a replacement speaker?
I also have a creaky door card where the speaker cover part is… but will take a closer look next time I dismantle the door as it looks like it has screws holding it together so should be able to do something there… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #596546 5th Jun 2021 8:34pm
TDV8 Paul
I’ve got this job to tackle, if I were you I’d go down the new speaker route I think 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #597150 11th Jun 2021 1:32pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Seems to be a common fault, genuine ones on e bay for less than £50 - or I think there is a thread on here about replacing with a generic unit.
Post #597183 11th Jun 2021 5:00pm
longi
New Zealand
I had this issue on a 2011 with Logic7, bottom left speaker. Went to the trouble of taking the door card out to see what was causing the rattle. The speaker was broken and would rattle at high volume.
Ordered a factory new speaker and the rattle is gone. More importantly, the quality of the whole audio system has improved dramatically. I suspect that the rattle was causing some interference with the whole amp. With the new speaker the sound is much better control and bass pressure is significantly higher.
Post #599082 29th Jun 2021 9:52am
Chapeau! Velo
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Ive got the same issue and if I’m going to faff with taking the door card off I may as well have a replacement speaker on standby!
Post #599659 4th Jul 2021 11:30pm
longi
New Zealand
This really helped me:
Post #599660 4th Jul 2021 11:35pm
Ffrr-lover
So I eventually got around to this job this weekend! (My one successful planned job so far!)
As mentioned, the rattle was with the speaker itself and the replacement has made a huge difference. Not a difficult job at all, with the only tricky part was getting the door card off for no reasons other than it requires a bit more force that you fear will snap something! Once it comes off once, any other times are quick and easy.
Now that rattle has gone, I have a new one!
I believe that this is from the door card itself. Specifically the lower speaker cover attached to the door card is creaking to the touch and I think this is the source. My next job is to see if that section is removable (I suspect it is) and then to pack the joints with some form of tape to remove the squeaking. I’ll also order some more plastic clips for the speaker screws as I am not overly happy with the ones already there…
After removing the old speaker I had a good intrusive look at what caused the rattle, and can’t see anything amiss. I suspect there is little you can do to salvage a speaker in this state. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #609482 17th Oct 2021 1:04pm
TDV8 Paul
Thanks for the update, I’ve still not managed to get round to doing mine 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #609591 18th Oct 2021 1:34pm
Caesium
How odd, took my door panel off this weekend to cure a creaky door speaker cover and also discovered than it wasn't just the panel creaking, the speaker has blown.
I've ordered a pair of Pyle 6.5" drivers from Amazon which I'll be doing tomorrow hopefully (depending what time they arrive)
I'll take some pictures. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #609593 18th Oct 2021 1:59pm
Caesium
Ffrr-lover wrote:
I believe that this is from the door card itself. Specifically the lower speaker cover attached to the door card is creaking to the touch and I think this is the source. My next job is to see if that section is removable (I suspect it is) and then to pack the joints with some form of tape to remove the squeaking. .
The plastic speaker grille is not removeable. It's attached by what appears to be sonic welding (melting) some trunnions over at the end to secure it.
I've used felt tape to lessen mine creaking as it seems to stem from the union between the grille and the inner part of the door Christian.
Current Cars
2019 BMW X4
or
Post #609594 18th Oct 2021 2:02pm
Ffrr-lover
Urgh… that’s a shame. Looks like I’ll have to do something similar then. I need to sort a couple of other creaks dotted around in a similar fashion.
I had something similar many years ago on my 5 series. The wiper stalk had a button on the end that rattled, and the fix (apart from dismantling the steering column and replacing the stalk) was a tiny bit of tape wedged in the end! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #609631 18th Oct 2021 6:50pm
dhallworth
I’ve just replaced the big speaker at the bottom of the drivers door on my SC.
It was rattling at anything above low volume. Easiest and more reasonable price for a replacement was Rob at Duckworths. A nice simple job to swap it when it arrived too! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #609634 18th Oct 2021 7:13pm
