![]() | Home > Technical (L322) > Torque converter fault? |
deltic Member Since: 18 Jun 2018 Location: dublin Posts: 57 ![]() ![]() ![]() |
Bump
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
On the off-chance, display the 4x4 Info screen on the console display - the one that shows if you're in Hi or Lo range. Check if it switches to show Lo range when the fault occurs - caused by a dodgy potentiometer sensor track in the transfer box shift motor. This will disengage the TC LOC and maybe the cruise control as well. That may give it enough of a kick that the shift motor then reports it is in Hi range again so the TC LOC re-engages, and the process repeats as you kangaroo along. |
As it stands my radio isn't working due to the Bluetooth box having water ingress. When I go into the secret mode and access 4x4 info it won't recognise suspension being lowered or heightened, just shows it at middle height and won't read it changing heights or any other hi/ lo range box settings |
Jonnys19882 Member Since: 01 Jan 2021 Location: Goytre Posts: 53 ![]() ![]() ![]() |
For the radio, you can remove the fibre optic wires from the BT module and connect them together to bypass the broken module. You won’t have Bluetooth but your radio will work. There’s good videos on the net show exactly how to do it |
Plugged in the Icarsoft for transfer box and it's showing sensor short circuit to battery |
Got live data for the transfer box potentiometer
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
I am no expert on this subject, but after some digging around I found the below info, have not had the time to read through it all, but I hope this may help. The comments on the bottom are all part of the copy / paste.
This powerful uk video may help.
Loads of info on the potentiometer in this link, scroll down for pics.
Nice one Merchy!
I don't think anyone does actually sell the potentiometers. There were some moves to have some manufacturered ... as per that link ... but I don't believe it actually came to anything.
As for the unit being 'overidden' it's not something I would want to try, the consequences may possibly not be good ones. As I have not heard of this being done, it's not something I would try, just erring on the safe side.
