![]() | Home > Technical (L322) > Help Sliding pin spanner size? see500020 Front brake removal |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1215 ![]() ![]() ![]() |
13mm for the bolt, 16mm for the sliding pin. First make sure you scrape / brush off any rust / scale that may have built up on the flats. |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 ![]() ![]() ![]() |
Your a gent! |
If you cannot find a 'skinny' spanner, buy a cheap one and use an angle grinder, file or similar to reduce the thickness. Hope it all goes well |
As above, i have a slim set of spanners for this... |
16mm is too small. |
A 17 fit it in the end.
Ah well, at least you got there, my bits are all Pagid, must be slight differences in sizes, typical RR problems |
