![]() | Home > Technical (L322) > Battery Warning Light (TD6) |
Be worth getting your alternator checked before you run down the battery. |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
Plugged in the IID tool this morning and the battery was at 11.7 volts. Once the engine was started, with no illuminated battery warning light, it was showing 14.0 volts.
Could be either, a battery at that voltage is a discharged battery for one of two reasons, it's not charging or it is discharging itself.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
As above. Have you checked the alternator output when the warning light is showing? John
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
I had the same and upon striping the alternator apart found the brush gear worn to an extent where one of the carbon brushes was not making contact. Ordered some replacement brushes online and fitted them myself. Rebuilt and refitted and now has been ok for the past year + . Mine is a 52 plate TD6 with 167k on it. |
