![]() | Home > Wheels & Tyres > Shiny tyres? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
I use Meguairs , excellent for special occasions, but it doesn’t last very long, so mostly I use soap and water.
Pimpinthepidge Member Since: 17 May 2021 Location: Glossop Posts: 9 ![]() ![]() |
I use meguiers also, you can add more product to get a higher shine or just 1 coat for a quick clean look, I find cleaning the tire first with a stiff brush helps the product. I used to use whichever was on offer at the supermarket but found that the tires were cracking and looking old before there time. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
How old are your tyres? If they are old, some get porous and the tyre shine seams to soak in... |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Looks interesting... The reviews would suggest 'used sparingly' and wipe down afterwards, as it can attract road dirt/grime that can turn the grime brown. Petroleum based I believe. If not wiped down will spew over the bodywork - especially so in hot climates. Other's also say it last ages... Tyres need DEEP cleaning prior to using... I guess that goes with most products though... |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 795 ![]() ![]() |
Meguiars Endurance Tyre Gel
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 772 ![]() ![]() ![]() |
Yes, like I say, you only need a little bit. I always use the same applicator pad which is sodden in it, so I only need need a tiny drop to wipe over. It has great longevity in my experience. Here is a good comparison video of various products by John of the Forensic Detailing Channel. His comparisons are very fair and unbiased. Definitely worth a watch if you have a spare few minutes... Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Yes good points. You are correct about B&M and leaving with bags of stuff you probably don't really need. I tell the misses (naughtily) they have high infection rates and so she should not enter, or unless accompanied by a qualified peer reviewed psychologist. We once went out to purchase some top-up for a deep carpet cleaner thingy some friends loaned us, for about £9... but ended up purchasing a £5000 hot-tub we never had the money for, for our last abode!!! ![]() ![]() No more shopping for carpet cleaner top-up though... ![]() |
Yes I'll have to give the Meguiers a go - looks popular. And for a tenner you can't really go wrong. Yes good scrub up prior to application looks to be essential. Cheers! We do get some salt erosion/probs on tyres here since moving to the seaside. All our car's in last 6-years have been affected either by salt or bad roads. combos..... Suspension struts/arms too! |
Maybe the sponge application somehow helps it adhere better?!? Many say it sprays off if excessively applied. Looks jolly good stuff though. ![]() |
I suspect people go a bit mad applying it to get a shine, but working it in thinly with a sponge gives a good finish without any issues. |
Mnnnnn!?! Various ages from two years to two months. They are all higher priced budget ACCELERA IOTA which have already come under fire here - might have something to do with it. They do ride and wear AOK though - no probs there. The bloody beading or gill areas or square blocks of areas (that are apparently for tyre cooling?!?) on the tyres are a real nuisance to clean and shine... |
I had my hands on the stuff in Halfords today, £12.00 odd..... ![]() ![]() I hope one day I grow up to be confident enough to shop for myself... ![]() |
