![]() | Home > Wheels & Tyres > 19" Spare Wheel? |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 ![]() ![]() ![]() |
I always thought that Westie wheels were 20β like this one.
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 55 ![]() ![]() ![]() |
You most probably have style 15 19β wheels which were fitted to 4.4 Tdv8 Vogue. Earlier 19β wheels do not fit over front 6 pot callipers. Example of style 15 rim att. The Westminster, SE, Autobiography would have had 20β as standard.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2553 ![]() ![]() ![]() |
D4 19" rims will fit although it will sit 6mm further out and won't have the same pattern, but you might be happy with one as a spare. |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 200 ![]() ![]() ![]() |
Correct Just checked. I saw the one you linked to on Ebay, I was thinking too big. Just noticed the brake fitters bust my nuts |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 ![]() ![]() ![]() |
Quick answer is no. Not to a 4.4 tdv8, as above the older 19β wheels will foil the callipers so you either need a 19β D4 wheel or a matching one to whatβs on the car.
thanks, I amended above. they are 20"
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2042 ![]() ![]() |
I have 5 x style 15 rims that fit over the big brakes, if you want to go the for 19" |
In which case most 20β will fit, so more choice there. There is nothing that can't be fixed with a hammerππ
Thank you for the replies. Iβm going to stick with the 20β |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 773 ![]() ![]() ![]() |
Do you still have these available? ![]() ![]() |
