![]() | Home > Technical (L322) > TD6 Starter motor location |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I'm sure it's on the N/S of engine (righthand side as you look into bonnet) |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Yes - that's what I thought as the positive lead from the battery goes down there - also the other side is taken up with the exhaust and the turbo.
Never removed one, but usually remove the live lead and a couple of mounting bolts. A lot depends on how much you have to remove to get to it and the space to work around starter.
I'm dubious that its an easy job due to its location under the manifolds |
