Home > Technical (L322) > Not a trick question....
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
I have been told that the reason my new aftermarket foglights do not fit is because my 2009 L322 is an SE and not a 'standard' Range Rover...whereas, I am convinced the problem is that they have sent me fog lights for a 2010 model. Can anybody shed some light (ha!) on this matter for me please?
Post #595373 26th May 2021 11:08am
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
You've been sent the wrong ones. Mine (2009 Westie) are identical to yours, 3 fixing points, not 4.
BTW, if you are replacing them because of that misting on the lens, it's just wipes off from the inside with a bit of elbow grease - the lights come apart really easily. Mine did exactly the same when I bought the car and have been fine ever since (2 years now) 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #595378 26th May 2021 11:38am
Zeb
Thanks for that! I have a feeling they are trying to wriggle out of paying return postage by suggesting they are not at fault..🤔🙄
I will also try your suggestion to clean up the lenses...although the back of the whole units looks pretty corroded too!
Post #595380 26th May 2021 11:55am
