Home > Maintenance & Mods (L322) > WHEEL LOCATING PINS
its the same thread size [14x1.5] but if you are fitting the 2002-2005 OE wheels with the 20mm size shank nuts then the locating pins will be to big ..
if you have the newer wheels with the 23mm size shank then the locating pins will be ok... ... - .- -.
Post #595204 24th May 2021 4:49pm
mjdronfield
That’s what I was wondering to be honest.... I thought they were the same fitment... just the wheel bolt washer angle that was different, and the pin doesn’t have that on, so should be the same?
Ah, ok, cheers Stan... more than a single difference then....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #595210 24th May 2021 5:30pm
I ask as l have pins that l bought for my 2004 car with original wheels on it but l actually now have a set of 2010 wheels on it. I use the pins every now and again and they fit the later wheels without issue. As far as l can tell the pins are a universal fit and will fit any year FFRR.
Unless anyone can tell me different of course. Smile
Post #595211 24th May 2021 5:38pm
your 'now' wheels fit cos the old pins are slightly smaller in diameter? ... - .- -.
Post #595221 24th May 2021 6:22pm
Stan, my pins are 20mm día so you are probably right but why would you manufacture a bigger día pin just because the wheel hole was bigger.
The pins just have to fit the 14mm día thread and then have enough wall thickness to be sufficiently robust to hang a wheel on without failing. Obviously 20mm día is sufficient.
These pins don't have to be an exact fit, in fact loose is probably better.
It would seem therefore that pins for 2003-5 cars are indeed universal but pins made specifically for 2006 on aren't. Thumbs Up
Post #595224 24th May 2021 6:33pm
i agree...i dont know whether the newer pins are 23mm or like your 20mm ones.. ... - .- -.
Post #595226 24th May 2021 6:43pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Can someone measure the 03-05 pins and send me the details please.
Have looked on the web and cant find anything.
TIA
littlecub
Post #595231 24th May 2021 7:22pm
I'll measure them in the morning for you. Thumbs Up
Post #595234 24th May 2021 7:32pm
Here you go. Thumbs Up
Post #595282 25th May 2021 10:24am
Merchy
nicedayforit - Nice info and drawing. Thank you, it will save me the job of measuring up. I will take the drawing to sea with me to make a set, or be lazy and tell the fitter to make them up for me when he is not too busy Whistle
I agree on the 'loose is better' point, more wiggle room.
That drawing HAS to be from someone from an engineering background Sir. Stands out a mile Thumbs Up
Post #595288 25th May 2021 11:00am
littlecub
Thanks from me also nicedatforit. Bow down Very Happy
Now to find an engineering place to do it lol
cheers
Post #595339 25th May 2021 8:04pm
