Home > Maintenance & Mods (L322) > Easy fit transmission pan. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1183 |
I would remove the plastic piece mentioned ASAP, if I were you, it is probably restricting the oil flow, you could well damage the gearbox |
21st May 2021 7:43pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Do you mean this:
21st May 2021 9:37pm |
It may help to state exactly which replacement part you used, Maker / type etc.
22nd May 2021 5:17am |
tommo10ferrets Member Since: 29 Apr 2020 Location: leicestershire Posts: 56 |
Morning all, yes, that's the bit, there was no instructions with the pan, if it was put on for transportation protection it looks over engineered, a simple cap would have sufficed, i watched 3 videos on YouTube last night, 1 of them, an Australian mechanic said he didn't know what it was & suggested it was for protection, took it off & fitted, the other two, one a French mechanic left it on, didn't mention it & fitted, the other one was from Rimmerbros, he didn't mention it either & fitted it. so I don't know lol, as i said earlier, it sort of looks right if you know what i mean, I bought it from LR, Liverpool, when I had a web chat with them he said remove it because it won't filter the oil, I think he was mistaking the bit I was talking about with the cap on the filter, I may be wrong. Thanks for all your replies, it's appreciated, i may ring Rimmerbos & ask them, I won't be dropping the pan until tomorrow so may get a definitive answer by then, I'll update later if I have any news. Thanks all. Tommo |
22nd May 2021 9:02am |
It is odd, because some pans appear to have this plastic cap, and others do not. My one didn't have it. .
22nd May 2021 9:57am |
Just come off the phone to Rimmerbros, no help there unfortunately, they didn't know, so I've emailed LR, Liverpool where I bought it from & asked them to email any instructions that should have been in the box, wait & see now, but think you'll agree that it looks right & just not a transportation protection, hopefully we'll see.
22nd May 2021 10:24am |
Afternoon all, Just had an email back concerning the white plastic bit, It's got to come off !!!!! Well at least I have a definitive answer now, hopefully it will help other members if they have the same problem, Still think it looks right though lol.
24th May 2021 10:13am |
Morning All, just a quick update, drained the pan, took it down removed the plastic bit, put all back together, took the car for test drive, all seemed ok, got home, checked underneath, got a leak !! so have got to sort that this afternoon. But the good bit, if I can call it that, is, I was on line last night, came across this, follow the link, have a look at the second part down, 2 plugs part, https://mjproducts.com.au/zf6hp26-automati...c98ba2045f
25th May 2021 10:42am |
