Home > Technical (L322) > advise please wear does this connect |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Difficult to see, could be the brake pad wear plug.. you should have one O/S front and one O/S rear... Pete
20th May 2021 10:45pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
FBH pump connector (you may not have one, but the wiring is there) .
21st May 2021 8:32am |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
hi all many thanks for your help not the brake wear wire that is all fine but thanks . i think joe 90 has got it fbh pump connecter i have zip tide it up . just to ask is that fbh pump normale at the rear of the sub frame joe 90 thanks oggy new vehicle purchase
21st May 2021 6:27pm |
Yes, if you have an FBH, the fuel pump for it lives up on top of the subframe just past the upper wishbone (looking from the side). It is a pain to get at or even see it unless you lower the subframe a bit. Consult RAVE or the later WM for more info. .
21st May 2021 9:42pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Mine has some spare plugs in that area, which I think are for the tyre pressure sensors if they were fitted. |
22nd May 2021 5:49pm |
thanks for every ones input i would say joe 90 has got it i have had a look at my build sheet and no pump fitted so have zip tied it up out of the way thanks to all oggy new vehicle purchase
22nd May 2021 7:03pm |
