Home > Technical (L322) > L322 2011 Towbar electrics
Shovie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Bournville
Hi,
Having changed the gearbox oil & rustproofed both rear wheel arches & applied the additional wheel arch rubber protectors my only outstanding job is the electrics on the towbar. Everything works except the caravan left & right side lights, could it be the Trailer control module? Any help appreciated.
Thanks
Dave.
Post #594653 18th May 2021 9:04pm
rjff
Dave
Might be teaching granny, but before you chuck yourself at the module, have you checked the wiring for power and/or breaks, the car socket/s for corroded or failed connections and the 'van lights and wiring themselves with a 12v power from a battery? Cheers
Richard
Gap IIDBT
Post #594687 19th May 2021 10:13am
Shovie
Thanks Richard,
I know its the RR as I tried it with another car & it worked OK.
Post #594766 19th May 2021 11:09pm
I would start with the socket.
Have you got 13 pin or 7? The wiring on the 2011 hasn’t got the fag packet like the older cars, it’s a straight plug in job. So you would be into the cars electrics if it’s not the socket.....
I would start with checking the power at the pins to rule out bad connection or bad earth. There is nothing that can't be fixed with a hammer😜😜
Post #594778 20th May 2021 7:40am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Get a test lamp or a meter and check between the following pins and the chassis. Pin 7 L.H. Side lamp, Pin 5 R.H. Side lamp. Both should light the test lamp or show 12v on meter between the pin and the chassis. If they show live then do the same but this time instead of the chassis connection, connect to pin 3. Pin numbers are correct for both 7 pin and 13pin trailer sockets and of course you need the side lights on when testing. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #594790 20th May 2021 10:05am
Shovie
Thanks all,
Its a 7 pin socket, are we saying there is no trailer control module on this year?
I will probe about when it stops raining & report back.
Dave.
Post #594829 20th May 2021 6:06pm
Shovie
Hi,
Today the sun shined so I was able to meter the pins & discovered that the 2 brown wires on the plug should have 12 volts with the side sidelights on but did not. Can anyone advise where these wires next go so I can trace them back without unravelling the loom protection?
Thanks
Dave.
Post #595394 26th May 2021 4:17pm
AJGalaxy2012
PM Sent BMW i3 Electric Car
Post #595426 26th May 2021 8:42pm
Shovie
Many thanks for the PM, exactly what I need. How can I physically find the location of trailer ECU D221? Is there a component map?
Thanks
Dave.
Post #595443 27th May 2021 5:47am
Shovie
Hi,
Pleased to say that I have resolved my problem, it was a fuse in the passenger fuse block, thanks for all your help.
Dave.
Post #595550 27th May 2021 8:01pm
AJGalaxy2012
Well done that man! BMW i3 Electric Car
Post #595552 27th May 2021 8:17pm
