L322 central locking & headlamp wiper | |
Need some help regarding the drivers door lock...... car locks and unlocks all doors using both keys but the remote will only lock and unlocked passenger front and both rear doors....from looking on the info here it appears the signal comes from the BCM....I have changed the door actuator and nothing has changed looked at the wiring in the door but as it works on the key I’m assuming that’s ok too.......can diagnostics interrogate the BCM?
Also the near side headlamp wiper motor does not work and I’ve fitted a working one, when I plug it in I works ( I assume to reset) but then nothing...again the command comes from the BCM, off side works fine (once I replaced that too)....has anyone come across similar issues.....thanks in advance ![Thumbs Up Thumbs Up](images/smiles/icon_thumbs.gif)
