Home > Maintenance & Mods (L322) > Bird's Nest!
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Bird's Nest!
Dragged this little lot out from behind the osf fog light - almost completely blocking air flow to the radiator that is tucked away down there. Air-con rad??
 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #594608 18th May 2021 2:43pm
rjff
Impressive, the owner could be big enough to give you grief when it gets home. Whistle
Cooler is the auxilliary engine coolant cooler, alledgedly for the TDV8 in warmer climes and higher loads such as towing. Have a look in the WM in the Wiki.
HTH Cheers
Richard
Gap IIDBT
Post #594618 18th May 2021 4:06pm
