Home > Technical (L322) > 4.4 M62 Headgasket? |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 918 |
Welcome aboard......before we go any further.....is it fitted with lpg ? |
16th May 2021 7:22pm |
Tobyrm1 Member Since: 16 May 2021 Location: Bristol Posts: 6 |
Thanks for the welcome. No it is not on lpg. |
16th May 2021 7:48pm |
Well we can rule that out then, hg failure is not unheard of and at that milage water pump and valley pan gasket isnt surprising either.
16th May 2021 9:04pm |
It was an eBay kit but we did test it on two good known petrol cars and it stayed blue coloured.
16th May 2021 9:33pm |
If you tested the kit on known good engines it's fair to say it's ok.
16th May 2021 10:24pm |
The kit definitely worked by changing colour in the presence of co2. With the two known good engines it stayed blue. Then when we bubbled exhaust gasses through it turned instantly yellow.
16th May 2021 10:38pm |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 |
Hello Toby, you say you've done a compression test, but have you done a cylinder leakage test too?
17th May 2021 10:44am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8339 |
At that mileage I think if it's running OK and not spewing up coolant after 15mins sat in traffic then I'd leave it well alone... just my 2p... Pete
17th May 2021 11:26am |
Thanks. That was going to be my next port of call. I just thought the fact that the combustion gases in the coolant chamber was pretty conclusive to headgasket? |
17th May 2021 10:17pm |
I think the point is it keeps blowing the next weakest part of the cooling system which obviously isn’t economical when the root of the problem can be fixed. |
17th May 2021 10:19pm |
Bite the bullet and pull the heads if it his intention to keep the car |
18th May 2021 7:19am |
Yes I'd agree, it's normally a very good indicator as in most engines a compromised head gaskets is the only way exhaust gasses can get into the cooling system unless you're really unfortunate and have a cracked head, or worse, a cracked block.
18th May 2021 8:09am |
