![]() | Home > Technical (L322) > What do these wires do? |
wpo750 Member Since: 17 Nov 2018 Location: London Posts: 32 ![]() ![]() ![]() |
A little more info on this one. The 5.0 supercharged I picked up in January I had trailered back to the dealer last month whilst it was still under warranty as the EML kept coming up indicating cam position actuator issue by the iid tool. This was allegedly rectified by sorting out some wiring to the ECU so I spent the day on public transport to collect the car.
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
What about arranging for a mobile auto electrician to take a look whilst the vehicle is at your mechanics place. Might save you a lot of time and money in the long run 2011 TDV8 Vogue SE |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1311 ![]() ![]() |
As a start, With the 4th wire down disconnected,
Is it the 4th wire down with a 50A fuse? shown disconnected?
Note diagram shows 30A fuse to be fitted. 2018 SE SDV8 4.4 Byron Blue |
In the Wiki there is a electrical library this may be the legend guess it depends on year etc
I think an auto electrician is on the cards if he's still scratching his head tomorrow!
So... Does anyone have a contact of a decent auto electrician in the SE London area? I've tried getting in touch with all the locally listed ones but none of them will even answer their phones. I wonder if my number is listed as a Range Rover owner and they've got their barge poles out? |
Bit of an update on this issue. It's still laid up and hasn't turned a wheel since the original post but last week an auto spark paid it a visit and diagnosed it as being a faulty instrument cluster which is causing the parasitic drain.
LiftedDisco Member Since: 13 Nov 2019 Location: Towcester Posts: 32 ![]() ![]() |
There’’s a chap in Leamington Spa who does dash / instrument binnacle rebuilds for D3’s and is a wizard with such things - he did our daughters while she waited and offers a fully guaranteed service.
Sorry, Rugby, not Leamington...
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Let me have the numbers from yours, i have a couple kicking around here sir...
Thanks guys this is all helpful stuff!
Part numbers or engineering numbers on the label or printed in the plastic on the screen sir... 👍 |
