![]() | Home > Maintenance & Mods (L322) > No heat from heater on 2008 L322 Vogue |
Ian Daniels Member Since: 09 Nov 2018 Location: Norwich Posts: 5 ![]() ![]() ![]() |
Been having heater problems on my 2008 L322 Vogue. Air cond working but no heat. Looking at the forums I found:- Heater control valves (replaced them, no difference), Airlock (bleed the system 5 or 6 time no difference), FBH pump and secondary pump (remover and tested, no difference) now time to think for myself. Fired up the FBH from cold and felt the 3 pipes going to the heat control valves and found the bottom pipe gets very hot (FBH to valves) then the two upper pipes (valves to heater) started to get hot but very slowly, then the FBH started to kettle and shut the FBH down on overheat. So pumps working, heater control valves working, FBH working and no circulation, after looking at the heating diagram in the manual the only thing left in the circuit was the changeover valve which decides weather the coolant for the heater comes from the engine or the heater return. I thought if it was stuck it would still allow coolant from one of the inlets, WRONG! I removed the cabin air plenum (the pollen filter housing) (remove the rubber seal from the rear of the engine bay, remove two nuts, one either side of the plenum, and pull the whole plenum forward and out) and you will find the changeover valve bolted to the bulkhead on the right as you look at it from the front of the vehicle. Remove the three hoses from the valve and unplug the wires, remove the two nuts from the valve bracket and remove from the vehicle. Remove the valve from the bracket, remove the 4 screws around the top of the valve and pull it apart, clean and lube with silicone grease and put back together, put the vehicle back together, fill coolant, bleed and hey presto, heater works, FBH works. |
The valves are connected to the bulkhead via 3 aluminium pipes, the bottom one is the flow from the FBH so carrying the hot coolant to the valves, the top two are carrying the hot coolant to the matrix. On mine if I felt the bottom pipe and it was getting very hot but slowly, then the heat started going through the top 2 pipes but slowly again, therefore the 2 control valves were open but the system was blocked somewhere else, and the only other point was the changeover valve. When I removed the changeover valve I tried blowing through it and all 3 ports were blocked. I use Regin silicone grease as I used to be a heating engineer and it sits on the shelf but any lube that won't attack rubber will do the trick. Good luck. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Hey Ian,
If your heater works with the engine running that rules out the temperature control valves and looks like the changeover valve as it is used to changeover from FBH to engine coolant. A right sod to get too but mine was easy to fix with just a clean and lube. Good luck, hope it goes well for you. |
Just be careful when removing the valve and bracket from the bulkhead as they have used nylon nuts and they round off very easily. Best to use a 6 side socket. The valve isn't an open close valve it's a 3 port valve, out to the temperature control valves which splits it to two and feed the heater matrixes, in from the FBH and in from the engine coolant. When the engine starts the FBH starts and feed the heater, when the engine reaches a said temperature the FBH shuts down and the changeover valve switches to the hot engine coolant. My valve had stuck in the middle and nothing was flowing. |
I’ve had it out tonight, wasn’t too bad I decided to clamp off the FBH and matrix return pipes and then take it out with the third still attached which I kept high to avoid dropping too much coolant.
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Please note that the rubber seals in the changeover valve can swell enough to block flow regardless of valve position. 2007 L322 3.6 TDV8 Stornoway |
Ian,
Good point, on mine the flow was perfect from both sources when operated by hand ![]() FBH ran fine this morning... fingers crossed. |
tigert Member Since: 15 May 2021 Location: Leicester Posts: 4 ![]() ![]() ![]() |
Help! I have put the problem down to the control valve but cannot remove! Is ther a way of in doing the 4 screws on top and doing it in situ? |
HJi. Is Ian Daniels still on here?
Just trying to bring my Posts up to 3 so I can message! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8389 ![]() ![]() ![]() |
Ian Daniels last posted in 2018 so I doubt he is on here any more...
Thanks Pete. I can get to it in situ and remove the 4 screws on the top but cannot it apart as more than likely seized and would like to know what it contains! i.e. if iI do get the top to lift out, will I be able to clean and grease and then slide it back together? I cannot find anyone selling a second hand one on the internet so I could have a go on the bench before trying to force it |
