Home > Camping, Caravanning and Holidays > Poor quality British vans? |
If it’s leaking then I would be trying to get that sorted under water ingress cover from the manufacturer. It shouldn’t leak.
13th May 2021 8:51pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1140 |
It's a Buccaneer Commodore. Should have said we've had it 8 months. Contacted Buccaneer and because we didn't buy it from a franchised dealer they won't cover the repairs. Dealer we bought it from have a huge backlog but it will be going back.
13th May 2021 10:48pm |
Totally agree. In my mind the only things which get nicer as you get more expensive is the cabinetry and cushions. The shell of the expensive vans is somewhat the same as the shell of a cheaper van. So your commodore is pretty much the same structurally as an svante 860, different decals and paint, but put together in the same way.
14th May 2021 7:49am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
I don’t want to temp fate here but our 2015 Swift Elegance has been pretty good, we purchased it at 2 years old private and swift did a few of the niggles (leaking taps, and sticking catches) under the remaining warranty.
14th May 2021 7:55am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 665 |
Always amazed that all the modern technology in the world & we still get water ingress.
14th May 2021 8:00am |
Interesting about the composite floors on the swifts, afaik even thought the baileys are alu-tec construction the floors are still timber based. I like the look of the plastic sandwich floor at least then if it leaks there is absolutely nothing to rot. Im less bothered about water ingress when the underlying construction isn't damaged by it, it is then a pain in the bum rather than something which will destroy the van.
14th May 2021 7:03pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 361 |
We’ve had two Bailey and one Eterniti caravans and now own an Adria Izonso which we we bought nearly 4 years ago. I can safely say it’s been the best caravan by a country mile. We’ve had no faults whatsoever. The build quality is excellent and the layout perfect for our needs. It was also significantly cheaper than similar uk vans with a similar layout.
15th May 2021 9:16am |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
Do not buy a Lunar Caravan !! |
15th May 2021 10:17am |
Made me laugh Wogger. My van before I got the Buccaneer was a 2017 Lunar Clubman. That leaked from the inside from the Alde heating. |
15th May 2021 11:09am |
Not known as ‘leaky Lunars’ for nothing mate |
15th May 2021 11:44am |
Double L's apparently in the trade, or so the chap was saying at the dealer the other day.
15th May 2021 12:19pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Caravan Industry is trying to modernise with new materials including composites and sandwich panels, they struggle with the joints, glues and sealers don’t take to many of the materials well plus cheap unskilled Labour means there is often gaps in sealers and glues, screws driven through and other build issues coupled with poor designs with many joints and holes that mean leaks are almost guaranteed.
15th May 2021 3:01pm |
15th May 2021 4:24pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1463 |
The mainstream UK caravan manufacturers are complacent with their position in the market, they really dont care about their customers at all. When Bailey first started with Alutec caravans and wet heating, they grossly miscalculated the heating required in rear washrooms. When customers complained they offered an upgrade to a heated towel rail which included a small radiator, this was done at the customers expense. Ditto with some leaks etc and often the get out re servicing and warranty etc. Absolutely abysmal. Some swift caravans had cracks appearing in sides, Swift said this was due to pot holes in the road, IF pot holes had caused the issue to me the who;le van is not fit for purpose. Cracking front and rear ABS panels on many makes also was a common issue, manufacturers again trying to duck out of their responsibility.
15th May 2021 5:11pm |
