![]() | Home > Off Topic > Home WiFi |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
We have the Tenda Nova mesh network and it's great. It was super simple to set up and you just place the boxes around the house. I even placed one of the nodes in the shed to we have great WiFi in the garden too. Kev
Wifi does not go well through stone. My house is mostly wooden but has cast concrete floors for the underfloor heating so the network doesn't go across floors.
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
With the same SSID and set on non-overlapping channels, my devices roam pretty seamlessly between my two APs. At least I've never noticed an issue and I don't have to change networks. |
I could do that, but what I find is the device sticks to the poor one as long as there's a connection.
Yes, I know what you mean. I set up a rule on my APs which kicks off devices when the signal falls below a set threshold. That did improve things quite a lot. 2016 Skoda Octavia VRS Estate
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 ![]() ![]() |
I have the same problem and also wanted Wifi throughout the garden so invested in a Ubiquiti Unifi set up which probably owes me at least £1000 (and I installed it myself + some fixed ethernet plumbing by my electrician). But I get great performance in every room and outside. T set it up is kind of simple but really you need to know what you are doing or be prepared to read up an awful lot. The quality of the products are business-grade if not quite enterprise grade.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1452 ![]() ![]() |
I too now have a Ubiquiti set up at home and the difference compared to "consumer" products is astonishing.
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 ![]() ![]() ![]() |
I've previously hard-wired the important bits of my house with ethernet cabling, the only awkward bit as expected was finding ways to route the cabling so it's completely hidden (some of mine goes out the wall and down into / along the gravel soakaway at the base of the walls, then back in where I need it). There is only one telephone socket, right inside the door, so rather than have to start there I put a network switch ontop of a kitchen cabinet and used that as the start point, with a single cable to the router (using the switch also means I have the advantage of being able to connect 24 devices instead of the standard 4).
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 601 ![]() ![]() ![]() |
I've got one of these Netgear Nighthawk mesh systems https://www.ebay.co.uk/itm/154237993098
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 731 ![]() ![]() ![]() |
We live in a big 1930’s house and every wall is thick and solid, we just switched provider to Gigaclear fibre and it uses the Linksys mesh kit and its great. One of the additional mesh ‘receivers’ is in the kitchen and gives enough signal to pick up the wifi in all of the garden too |
Mesh WiFi is really useful. Optimum WiFi access points will always be wired, but wireless mesh solves dead spots and those solutions are feasibly priced. Assuming a full-on home networking solution (like UniFi) is not used, I’d normally look at powerline + powerline WiFi, and specifically Devolo (other electronics providers ain’t good enough for me, so far). L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 ![]() ![]() |
Fill yer boots with information from my mate Vince . Bloke is excellent .
